Changes
- Log license errors to Graphic Hub journal and increase license grace period to 72 hours. (VIZENG-22295)
Bug Fixes
- SDC01: Viz Engine reports wrong IP in IpDeviceList messages (VIZENG-19999)
- SDC01: Switching 2022-6 inputs via SDC-01 doesn’t work (VIZENG-20499)
- Wrong text bounding box with carriage returns (VIZENG-20560)
- Leading space when writing direction is right to left is not working for Font File (VIZENG-20714)
- Leading space when direction is vertical is not calculated in bounding box (VIZENG-20715)
- Softclip plugin performance in 3.12.x (VIZPL-1083)
- Aja input drops frames (VIZENG-21151)
- High CPU usage with new Softclip plugin (VIZPL-1096)
- Viz crash in SoftClip plugin (VIZPL-1125)
- NLE frame server crash caused by resource leak (VIZENG-21959)
- Texture memory increases when Viz is running in console mode (VIZENG-22030)
- Using Softclip plugin with repeating still frames in Lagarith (VIZPL-987)
- Improved warning reporting for 64bit Softclip Plugin (VIZPL-1241)
Read the Viz Engine notes 3.12.2 on the Vizrt ftp following the path: products/VizEngine/VizEngine3x/Previous Versions/3.12/3.12.2/ for more information.
