Why now is the time to migrate from Viz Pilot News to Viz Pilot Edge
Don’t let Legacy tech slow you down: Make the switch to Viz Pilot edge now
Viz Pilot Edge delivers faster workflows, stronger security and continuous Innovation, and is built specifically for the speed and demands of modern newsrooms like yours.
by Andrei Kolmogorov, Vizrt Migration Expert
Blogs
In modern newsrooms, being first matters – which means every second in time matters. Whether it’s breaking news, real-time graphics, or seamless integration with your production environment, your tools need to be fast, reliable, and secure.
If you’re still relying on legacy templated graphics technology, you are missing out on clear advantages: stronger security, faster workflows, and a platform that evolves with your newsroom needs.
This article explains why migrating from Viz Pilot News to Viz Pilot Edge is essential – not only to protect your operations today but to give your team the tools they need to thrive tomorrow. I’ll also cover the key steps for ensuring a seamless transition and the vital importance of keeping your software up to date once you’ve made the leap.
What you gain with Viz Pilot Edge
Technology evolves rapidly, and systems that were cutting-edge years ago often struggle to keep pace with modern demands. It’s like trying to stream a movie on a dial-up modem – it just cannot keep up.
Viz Pilot Edge delivers faster performance, smoother integrations, and an overall more reliable experience. Plus, it’s more secure. This translates into fewer disruptions and greater peace of mind for your team.
Security by design
Viz Pilot Edge is built on modern HTML and web technologies. With Single Sign-On (SSO) and frequent updates, your newsroom stays protected and compliant. Plus, server-side installations are simpler, which means fewer headaches for your IT teams.
Seamless integrations
Modern architecture easily connects with new tools, APIs, and third-party services, enabling future workflow enhancement. Viz Pilot Edge works with all major NRCS, integrates with Vizrt’s studio automation, and connects to the latest production and automation tools. Compatibility ensures your team can move faster without workarounds, ensuring your workflows are always ready for heavy duty news reporting.
Speed and reliability
With load times up to 4x faster (Viz Pilot Edge 3 onwards), your team can move at the speed of breaking news. A more stable product built on modern tech also cuts down on disruptions, keeping focus where it belongs – on the news story.
Futureproofing with advanced capabilities
From real-time updates to advanced 3D graphics, and more flexible scripting with HTML, Viz Pilot Edge gives you not only advanced creative options but also more room to innovate in template creation. And because the underlying technology is current and widely supported, onboarding new developers and training designers is easier.
Ongoing support and regular updates
Continuous product updates enhances functionality, keeps your newsroom aligned with mid- and long-term goals, and ensures that your technology investment stays protected. Built on modern standards, Viz Pilot Edge is designed to adapt with the industry – futureproofing in other words.
Stay current with the latest versions
Even after switching over to Viz Pilot Edge, staying current on product updates is key to maintaining optimal performance.
Updates deliver critical improvements that protect against security threats and fix bugs to ensure smooth operations, plus capitalize on the latest innovations.
The hidden costs of legacy tech
While the benefits of upgrading are clear, the risks of staying on outdated systems often remain invisible until they cause real problems or put your operations at risk. Outdated technologies such as ActiveX and VBScript (which are being phased out by Microsoft due to security vulnerabilities), can expose your workflows to a range of avoidable risks that could undermine efficiency and cost your team valuable time and resources.
Hover below to see more
Tap below to see more
Security Vulnerabilities
Older systems are often more vulnerable to security breaches. Without the regular updates and improvements that newer platforms provide, for instance Viz Pilot Edge’s Single Sign-On, your workflows and data could be exposed to cyber risks.
Compatibility Challenges
Outdated software often lacks compatibility with newer hardware, third-party platforms, or operating systems. This could force you into costly workarounds or even render some tools entirely unusable. You could face limitations when trying to integrate seamlessly with modern production environments, leading to gaps in functionality and increased manual work. Support may also no longer be available.
Limited Feature Set
The creative and operational opportunities available with Viz Pilot Edge (which is being continuously improved) are much more than what Viz Pilot News offers. This is due to the HTML and Vue framework being more futureproof. By sticking with an outdated system, you will be missing out on new features that could significantly enhance your team’s efficiency, creativity, and overall newsroom output.
Operational Burden
Legacy systems often demand extra technical team focus, just to keep them running. This could deviate resources from strategic projects. Also, it’s harder to hire and retain talent with knowledge of older technologies, making long-term support both costly and uncertain.
Work Smarter, Not Harder
Viz Pilot Edge offers a wealth of benefits that not only address the issues mentioned here but also empower your team to work smarter, not harder. By transitioning to the latest platform and continuous updates, you gain access to a toolset designed for modern media production.
When Vizrt launched Viz Pilot Edge 3 in 2023, it wasn’t just an upgrade. Our R&D team rebuilt the system from the ground up using modern web architecture to ensure speed, scalability and adaptability.
It wasn’t just a facelift. It was a leap forward designed to evolve with modern newsroom needs.
More importantly, Viz Pilot Edge keeps getting better with new tools and functionalities.
And because Viz Pilot Edge is centrally managed on the server side, upgrades are faster and easier than ever – no more time-consuming workstation-by-workstation installs. Updating regularly is key to maintaining optimal performance.
How Viz Pilot Edge keeps you ahead of the curve:
Futureproof your operations
Viz Pilot Edge is built with scalability and flexibility in mind. From seamless integrations with Vizrt production software and studio automation to compatibility with any NRCS and the latest production standards, it ensures that your workflows are always futureproof.
Enhanced performance and usability
Advanced features and functionality
Unlock a full suite of features designed to improve production efficiency and creativity. Whether it’s advanced 3D graphics options, scripting, real-time updates, syncing with your automation tools and other production software, Viz Pilot Edge boosts your workflows to a higher standard.
5 tips for a smooth move to Viz Pilot Edge
Transitioning to Viz Pilot Edge is easier than you think – and out team is here to help.
Here’s how to make the switch as seamless as possible:
Migrating to Viz Pilot Edge isn’t just about staying relevant. It’s also about unlocking your team’s potential and ensuring your operations run at peak levels. With a smooth migration strategy and the unmatched capabilities of Viz Pilot Edge, futureproof your newsroom operations with minimal disruption and maximum reward.
Take the first step
We’re ready to help you make the switch. Watch these video resources designed to guide you step-by-step through the migration. And, get in touch with Vizrt’s Migration Team to work out a plan for a seamless and successful transition.
Why Migrate Now?
Risks of Staying on Legacy Systems
Compatibility Issues
Older tools struggle to support modern hardware and software, forcing inefficient workarounds.
Feature Gap
You miss out on advanced capabilities that improve speed, creativity, and output quality.
Performance Decline
Slower load times, crashes, and bottlenecks become more frequent.
Security Weaknesses
Missing patches increase vulnerability and risk to data integrity.
Downtime Risks
Aging systems tend to fail more often, and support may no longer be responsive or available.
Benefits of Viz Pilot Edge
Security by design
Stronger security and centralized management.
Future-Proof Operations
Designed for scalability and support of next-gen production standards, with regular updates.
Performance & Reliability
Fast load times, stable integrations, and minimal disruptions.
Next-Level Features
Secure, real-time updates, and template creation tools.
Continuous Support
Regular updates ensure that you have the tools you need for your evolving newsroom, and timely support.
Recent Blogs
Tags
Tags
Blogs
See how Vizrt
helps its customers
Tags
Blogs
Tags
  • How Vizrt Education Solutions Prepare Students for Real-World Media Careers
    See how Japanese students used Vizrt’s TriCaster Mini S to deliver a live broadcast, gaining real-world media skills for future careers.
